Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Odd Oil issue
Thread: Odd Oil issue
Old 10-03-2012, 07:42 AM   #10
Jgrove998
Boost Addict
Jgrove998's Avatar
Fan#: 45311
What I Drive: 2004 SVT Turbo
Points 6,334, Level 51
Points: 6,334, Level: 51 Points: 6,334, Level: 51 Points: 6,334, Level: 51
Level Up 92% Completed
FF Reputation: 25 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by felixthecat View Post
Pull the balance shafts out & add a plug & stake it.
I would agree with this.
From what I know about the PCV system, air enters the valve cover from intake system (after the MAF so its already metered), flows down through the engine collecting contaminants finally exiting through the PCV valve to go back into the intake manifold to be burned off by the engine. If you pulled the PCV hoses and left the stock PCV valve, the valve is closed and probably won't open letting the nasty stuff out.
I would suggest the balance shaft delete and get the crankcase venting system setup correctly. Maybe even look into a oil cooler. IIRC the Ford Escape has a oil cooler setup from the factory; the oil filter adapter bracket will bolt right onto our engines; just need to find a suitable place to tap into the coolant lines after the radiator.
2004 SVT: bewst'd!
2013 Escape SEL 2.0 Ecoboost 4WD
2004 F350 6.8L V10 4x4
1986 XR4Ti 2.3L Turbo, 15 psi
Jgrove998 is offline
