Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Massive Crower cams installed 2009 focus, VIDEOS!!
Old 10-02-2012, 09:54 PM   #40
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 23,444, Level 94
Points: 23,444, Level: 94 Points: 23,444, Level: 94 Points: 23,444, Level: 94
Level Up 10% Completed
Forum Activity 100%
FF Reputation: 78 felixthecat Excellent Standing Member
Originally Posted by staticsword View Post
He said it was very straight forward and did not run into any problems, it took around 3hours for him to do it. He said you just have to make sure not to let the tension in the chain go, or it will turn into an 8hour job haha.
Thats what happened to me= I forgot 'bout the tensioner. So a couple hrs later I had the timing cover back on. It really wasn't bad. I only issue I had was you have to pull the p/s pump hose off to get to one of the bolts that hold the pump on the motor. Other then that no issues, used a new front seal that was in stock too.
felixthecat is offline
