Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil temp sky high
Old 10-02-2012, 07:06 PM   #7
SVTF 03
SVTF 03's Avatar
Fan#: 99859
What I Drive: A
Points 467, Level 9
Points: 467, Level: 9 Points: 467, Level: 9 Points: 467, Level: 9
Level Up 34% Completed
FF Reputation: 1 SVTF 03 Good Standing Member
Buy-Sell-Trade Rating: (5)
When topping off the coolant, leave the cap off the coolant tank and start the car and turn the HVAC control to hot. Let the car get up to full temp (190 degrees stock IIRC). This will help to ensure the coolant is flowing in and out of the heater core and using all the passages. I just replaced my thermostat housing / thermostat and haven't had an issue.
The oil to water heat exchanger (sandwich adapter) is between the oil filter and the block. From what I've seen... this basic design started on the first generation Lightnings and quickly migrated to the other SVT's and Ford cars as well over the years. The water reaches temp before the oil does and helps to get the oil warmer faster and helps to keep it at a safe consistent temperature.
SVTF 03 is offline
