Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Spring Opinions
Thread: Spring Opinions
Old 10-02-2012, 05:02 PM   #15
ProSilverVT02
ProSilverVT02's Avatar
Fan#: 33656
What I Drive: 2002 SVT
Points 2,031, Level 27
Points: 2,031, Level: 27 Points: 2,031, Level: 27 Points: 2,031, Level: 27
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 7 ProSilverVT02 Good Standing Member
Buy-Sell-Trade Rating: (8)
You can definitely keep the wheels, but consider running a smaller sized tire.
If you get down into the 205/40/17 tire size range you will decrease your width and height which should reduce, or most likely get rid of the rubbing altogether.
The ride, obviously will be a little rougher because of the smaller sidewall, but you shouldn't have any rubbing issues.
With that said, it doesn't hurt to replace your worn out suspension, but you probably won't see that drastic of a change by replacing your springs and shocks compared to running a smaller tire.
ProSilverVT02 is offline
