Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Heat After Coolant Flush
Old 10-02-2012, 02:08 PM   #3
diexodos
Fan#: 104141
What I Drive: 2001 Sand color Ford Focus ZTS
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
Level Up 90% Completed
FF Reputation: 1 diexodos Good Standing Member
Sailor, thanks for the advice. I am new on Focus and although I worked on other cars, each car is a unique experience by itself.
I will continue to flush and test the cooling system with distilled water. Once everything tests ok, I will replace the water with use 50/50 ethylene glycol antifreeze.
I will check all hoses and replace some of them. Can you send me a link for a proper bleeding of the cooling system? During testing stages, I will not be using the thermostat. Is it necessary to follow a bleeding procedure if the thermostat is not installed?
diexodos is offline
