Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 Ford Focus K&N Intake kit Released.
Old 10-02-2012, 01:32 PM   #273
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by VOLDAR View Post
- if you do the two mods that TboneZX3 has done (see here), the CAI becomes acceptable, there is almost no resonance and we can say the sound is not that of a factor if not at WOT. In fact, at 50% of throtle, the car is doing just fine.
I'm glad that worked out for you VOLDAR.
It's amazing how much different (quieter) the sound is when the MAF housing is properly suspended from the heat shield. I didn't mention this benefit when I originally did the mods, but the benefit is real. Just that little bit of contact that the housing has with the shield it has out of the box makes a world of difference.
It is a shame that K&N has done nothing to fix that issue, or at least they haven't contacted me about any design changes.
- the car sometimes sounds great under light throtle (a little different in growl) but sometimes, at the same throtle, there is a different sound.
I'll try and post some videos with it on traffic. I am still undecided about it. It IS LOUD when at WOT and this is something I have to deal with it. I give it another 3-4 days of test and if I decide not to keep it, it will be on the site for sale.
The difference in sound at a given throttle position seems directly related to engine load. If you load it up at 2K - 3K rpm, it will "moan" a bit, especially when loaded with A/C on. Give it a while and your driving habits will change slightly, and you'll be able to avoid the moan. If you're anything like me, you'll become really attached to the "wail" from 3.5K RPM to redline @ WOT!
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
