Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Turn Signal Lights Stay On
Old 10-02-2012, 11:04 AM
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 9,732, Level 66
Points: 9,732, Level: 66 Points: 9,732, Level: 66 Points: 9,732, Level: 66
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
Forum Activity 44%
Activity: 44% Activity: 44% Activity: 44%
Buy-Sell-Trade Rating: (15)
Originally Posted by joesperformance
blinkers are blinking really fast, but front and rear are both working.
Fast blinking usually means one of the lights in the system is out. You will have three lights on each side to check; front, rear and side markers. I know you said the front and rear are working but what about the side markers, they should be blinking the same as the front/rear?
I'd check each light individually (just remove and reinstall) and then try the turn signal.
If its not a light that is out then its a short or bad ground in the system. Id guess its probably not a fuse but its something you can check as well.
rambleon84 is offline
