Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - No Heat After Coolant Flush
Old 10-02-2012, 10:31 AM   #2
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 30,613, Level 100
Points: 30,613, Level: 100 Points: 30,613, Level: 100 Points: 30,613, Level: 100
Forum Activity 100%
FF Reputation: 128 sailor Excellent Standing Member sailor Excellent Standing Member
Plugged is a possibility, but I'd try to flush it out in reverse order (apply water hose to outlet) instead of trying to push things through from the inlet side as your note describes.
Air in the system is a common cause of such issues with this type of system that has a coolant tank higher than the radiator with bleed hoses to the tank from high points in the cooling system's plumbing. They are SUPPOSED to flow just enough to bleed out any air, but being quite small they are MORE likely than your heater core to be plugged.
Check out all those small plastic lines - once clear your problem may be solved!
Luck!
sailor is offline
