Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Focus on't start, but is fine 9 times out of 10
Old 10-01-2012, 05:05 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,838, Level 100
Points: 32,838, Level: 100 Points: 32,838, Level: 100 Points: 32,838, Level: 100
Forum Activity 38%
Usually when we see something like this- it's a loose battery terminal. Now you might think- oh the lights are on so the battery terminals are ok. Not always. It takes a lot of power to turn the starter, and if you have a loose connection it might not make up enough to be able to turn the starter but the lights are fine. The first thing you should do is to check these for corrosion, and if you find it- remove the terminals clean the lead posts, and the inside of the terminals, then re-install.
Now to make sure that your problem is not the PATS (passive anti-theft system) the next time the car doesn't start- look at the dash. If PATS is activated there is a yellow flashing yellow lock symbol. If you want to see that symbol follow this procedure to light up all your LEDs in the dash: Key off, press and hold odo reset button, turn key on, continue to hold odo reset button until the odometer reads [test] Now you're in test mode until you turn the key off again. Each time you press and release the odo reset button, you will scroll through one of 30 test functions. The second one makes the odometer read [leds], and all the dash lights will turn on. You'll be able to find that yellow lock symbol easily.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
