Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 ZTS - horrible gas mileage - 16.3mpg - HELP
Old 10-01-2012, 02:23 PM   #28
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,131, Level 27
Points: 2,131, Level: 27 Points: 2,131, Level: 27 Points: 2,131, Level: 27
Level Up 88% Completed
FF Reputation: 1 PWGuy Good Standing Member
Originally Posted by VEGAS View Post
Of course its a Automatic, his wife drives it :D j/k
I think its the wheel bearings getting old, they drag a bit more and with our automatics its another loss.. Automatics loose efficiency compared to the manuals when they get around 100k miles.. , yes I own both a manual and auto and I see a HUGE difference. You should be getting mid 20s even when car is not running optimal.. I would remove the tires, check for drag on spindals.
I have gotten in to the habit of popping into neutral when I slow down... lowers RPM of engine faster then leaving it in gear and car seems to stop JUST a touch faster, also less drag at a stop on motor.. I see 2 or 3 mpg difference.
I will remove the tires and check for drag on the spindals. I assume I just jack up one side and spin the tire to see if any dragging, similar to brake drag or caliper sticking? And I assume I do this for all four sides, correct?
Overall, you are right, we should be getting AT A MINIMUM low 20s in MPG.
PWGuy is offline
