Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Trunk Release Button on Dash doesn't work
Old 10-01-2012, 08:37 AM   #11
gonzo1954
Fan#: 104398
What I Drive: 2001 red 1600 zetec
FF Reputation: 1 gonzo1954 Good Standing Member
using small flat blade screw driver ,gently remove front of button from dash.you will see small white switch left in dash,press this if boot opens it is the part you have already removed from dash.if you look at the black peice you have removed you will notice 3 plastic ribs running downback of switch.these need to be shortened in length they are stopping front of switch connecting the micro switch when pushed.Use sharp blade and shorten all 3 by about 6mm and reassemble switch.BINGO IT WORKS
gonzo1954 is offline
