Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil temp sky high
Old 09-30-2012, 09:27 PM   #1
Davva
Fan#: 41632
FF Reputation: 1 Davva Good Standing Member
Oil temp sky high
Ok, I have replaced the head gasket. I also did the serp belt, timing belt, water pump, tensioners and pulleys.
Everything seemed to be running Ok so I took it out on the road. After about 2 miles the oil temperature went sky high. The water temp was normal and the oil pressure was normal. There was water in the radiator and the oil level was good.
I've heard talk of an oil cooler so I'm thinking this may be blocked.
Is that a good theory? And if so, where is it and what can I do about it?
All advice greatly received.
Thanks
Davva
Davva is offline
