Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Disconnecting negative terminal on the 2012 Focus
Old 09-30-2012, 08:09 PM   #2
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 1,502, Level 22
Points: 1,502, Level: 22 Points: 1,502, Level: 22 Points: 1,502, Level: 22
Level Up 2% Completed
FF Reputation: 5 dbenney Good Standing Member
Originally Posted by majorChibi View Post
Is there an easier way to do this on this car?
I'm going to be doing a speaker and amp install but the negative terminal is tucked away. It looks like I'd have to remove the battery itself to get the terminal off.
Is it ok to disconnect it where the battery grounds to the body?
you could do it that way, but id suggest disconnecting it at the battery. My reasoning behind this is GROUND. car grounds are finicky. If its working now and you go messing with the ground yu may have trouble later.
dbenney is offline
