Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - P0171 Help
Thread: P0171 Help
Old 09-30-2012, 07:29 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,441, Level 29
Points: 2,441, Level: 29 Points: 2,441, Level: 29 Points: 2,441, Level: 29
Level Up 94% Completed
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
Buy-Sell-Trade Rating: (3)
P0171s are usually a lean condition caused by a vacuum leak of some sort after the MAF. On the Duratec motor, the PCV line is particularly difficult to inspect and replace, iirc. There is a thread on FF with pictures. Edit: thread here
DTC definition from Ford:
P0171 - System too lean (Bank 1) The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
For lean and rich DTCs:
Fuel system:
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
A SHRTFT-1,2 PID value between -25% to +35% and a LONGFT-1,2 PID value between -35% to +35% is acceptable. Reading beyond these values indicate a failure.
BC_ZX3 is offline
