Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Zetec Rough Idle Mystery Solved
Old 09-30-2012, 01:13 PM   #5
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
What I Drive: 07 Infra Red ST,2002 ZX3.
Points 7,839, Level 59
Points: 7,839, Level: 59 Points: 7,839, Level: 59 Points: 7,839, Level: 59
Level Up 45% Completed
FF Reputation: 5 DueceCoupe Good Standing Member
Buy-Sell-Trade Rating: (29)
Originally Posted by drlenger View Post
no mine ran great once you gave it some throttle, just bad idle, you might get someone with good analyzer equipment to look at it. My EGR valve was replaced but was opening normally to 30% then slamming open the rest of the way and sticking open, made it pulse and bog down.....worth checking into. Have you checked into changing the throttle position sensor, you would have to change the entire throttle body because Ford changed it.
I will try to get video of what mines doing and post it here.....
Was the pulse from the EGR happening around 2-2300 rpms?
Mine runs great,once its rolling,but if I hammer the gas....bog than takes off.
I used to be DueceCoupe,but now I gots a 4 door!
ST Crew Member # 666
DueceCoupe is offline
