Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05' 2.3 ST with a few problems. Need guidance on where to begin...
Old 09-30-2012, 12:43 PM   #7
SilverST05
SilverST05's Avatar
Fan#: 103209
What I Drive: 2005 Silver Frost ST
Points 409, Level 8
Points: 409, Level: 8 Points: 409, Level: 8 Points: 409, Level: 8
Level Up 18% Completed
Forum Activity 7%
FF Reputation: 1 SilverST05 Good Standing Member
^^ I second that.
Adding that you should carefully inspect the coil boots- the rubber part that connects to the spark plug. Mine were bad around that time. The boot simply pulls off the coil- although it's easier if fold the plug end back past the coil first to break it loose. Look for cracks or other signs of obvious rubber failure. Boots cost about $5-8 each, and come with the spring and magnet inside. If you see any oil on the boots, then you need a valve cover gasket. Always install spark plugs with a dab of silver anti-seize on the threads.
Good call on the boots. I forgot I did that when I did the plugs. Really easy and fairly cheap for a little extra protection.
2005 ZX4 ST, Stealth CAI (so far)
Used to have, and will always regret selling, 1970 Mach 1.
"Everday is a good day, just try missing one."
"As soon as we're born we start dying, so you might as well have a good time."
SilverST05 is offline
