Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 05' 2.3 ST with a few problems. Need guidance on where to begin...
Old 09-30-2012, 10:22 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,447, Level 100
Points: 32,447, Level: 100 Points: 32,447, Level: 100 Points: 32,447, Level: 100
Forum Activity 48%
Activity: 48% Activity: 48% Activity: 48%
^^ I second that.
Adding that you should carefully inspect the coil boots- the rubber part that connects to the spark plug. Mine were bad around that time. The boot simply pulls off the coil- although it's easier if fold the plug end back past the coil first to break it loose. Look for cracks or other signs of obvious rubber failure. Boots cost about $5-8 each, and come with the spring and magnet inside. If you see any oil on the boots, then you need a valve cover gasket. Always install spark plugs with a dab of silver anti-seize on the threads.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
