Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - DTC code 1233 after fuel filter change
Old 09-28-2012, 10:06 AM   #3
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
What I Drive: 07 Infra Red ST,2002 ZX3.
Points 7,839, Level 59
Points: 7,839, Level: 59 Points: 7,839, Level: 59 Points: 7,839, Level: 59
Level Up 45% Completed
FF Reputation: 5 DueceCoupe Good Standing Member
Buy-Sell-Trade Rating: (29)
No better.
At this point,idle is still rough and a huge bog off the line when going wot.Car also has strange flutter/fluctuating surging around 2000 rpm.
Have so far replaced:
Plugs,wires,egr valve,pcv valve,pcv tube,dpfe sensor,checked for vacuum leaks with carb cleaner,new fuel filter.
Called Ford,no recall on fuel pump and sounds fine.
Only things I can think of is ignition coil (although pulling any of the 4 spark plug boots makes Car run badly) so I believe it to be fully operational,or new injectors???
Any ideas Guys?
This is really starting to irritate Me.
Car also does all of this if I run with or without My tune.
I used to be DueceCoupe,but now I gots a 4 door!
ST Crew Member # 666
DueceCoupe is offline
