Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT running but only just
Old 09-28-2012, 12:20 AM   #7
Fan#: 41632
FF Reputation: 1 Davva Good Standing Member
Originally Posted by drostedrummer89 View Post
If you get engine near tdc, insert pin, rotate engine clockwise and feel it hit the pin, then the bottom end is for sure at tdc. Cam slots only work one way. If you got the bar in, then its the cylinder head is at TDC..
Low compression is normal for svt from what I'm told, due to the VCT.
Posted via FF Mobile
Thanks for the input Matt. I had another look at the cams and there's no way that the bar will go in with the cams the other way round. I turned the engine round until it hit the pin and the bar slipped in very easily so I'm thinking this is right.
So the timing is right and I've changed the plugs and wires.
I don't know what to try next.
Any ideas?
Davva is offline
