Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help. 2000 Zetec spitting out coolant from plug holes on valve cover!
Old 09-27-2012, 06:03 PM   #28
diexodos
Fan#: 104141
What I Drive: 2001 Sand color Ford Focus ZTS
Points 295, Level 5
Points: 295, Level: 5 Points: 295, Level: 5 Points: 295, Level: 5
Level Up 90% Completed
FF Reputation: 1 diexodos Good Standing Member
I am not sure if Steal Seal will work on those plugs. I did use it on my 2000 Nissan Truck that had a blown gasket and the gasket got fixed within a couple hours. I almost did not believe it.The sealer works on repairing minor head gasket leaks only but you will need to follow the directions. You can use it as a preventative measure too.
Curious to know if it will work for your application.
diexodos is offline
