Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Failsafe Thermostat opinions?
Old 09-27-2012, 04:48 PM   #1
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I think it's Motorad that makes the Failsafe design.
I'm inclined to believe that most replacement parts are designed to fail. Even Ford had a batch of thermostats failing on the 2012 Focus'.
So if a thermostat is going to fail - pray that it happens in the 'OPEN' state - especially if you are on the road far from home.
Does anyone know if the normal operating temperature range of the Focus is compatible with the temperature range of the Failsafe thermostat, from experience? A little low on water and the radiator can barely keep the temp down where it should be - until the fans kick on. That's if you don't have a fan problem.
I'm just doing a flush and everything is working fine but am curious as I'm replacing a three and a half year old thermostat.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
