Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford Focus ZX3 Disassembling the base shifter tower ('base shifter plate')
Old 09-27-2012, 01:07 AM   #3
Fan#: 92148
What I Drive: 2001 Blue ZX3
FF Reputation: 3 Oblivion Good Standing Member
Originally Posted by iminhell View Post
How do you remove the shift lever.
The black portion is a rubber gasket of sorts. Underneath it is a 2 piece hunk of plastic that acts like a bushing for the shift lever.
OK! I tried pulling straight up on it. But there's still something holding it together.
I'm assuming the spring has something going through the center. How do you properly remove that?
Do you just take a flathead screw driver, and pop off the plastic spirally thing (opposite of the metal plating; By 1st/2nd gear)?
Image of where I'm at so far:
Thanks for the answer, by the way. I'd like to get this solved before work tomorrow.
Oblivion is offline
