Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - POLL: K&N Intake
Old 09-26-2012, 03:15 PM   #21
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
What I Drive: '01 ZX3, '12 SE Sport
Points 1,831, Level 25
Points: 1,831, Level: 25 Points: 1,831, Level: 25 Points: 1,831, Level: 25
Level Up 31% Completed
FF Reputation: 12 TboneZX3 Great Standing Member
Originally Posted by dyn085 View Post
In non-RACECAR driving (below 3200 rpm), the Typhoon was showing roughly 5 hp less, with up to 8 ft lbs less tq.
Another thing to consider here is that you're at WOT on the dyno. Will the effect you're seeing at WOT at those RPMs (below 3200 rpm) affect real-world, part-throttle driving at those RPMs in the same manner? A dyno works great for finding max hp or torque at a given rpm, but isn't really a tool for part-throttle efficiency analysis.
I keep close track of MPG tank-to-tank, and I saw no noticeable change in MPG going from the stock intake to the Typhoon. I would be more willing to believe that anyone who sees a drop in MPG with an intake swap is using more go-pedal because he likes the sound of the new intake.
HN #90
Mk3 |╠╬╝|SGM|203a|Moonroof|17" Paint/Mach Whls|K&N 57S-4000 -snorkel|FFE RMM|Steeda STB, RSB|JBR bushings
Mk1|╠╬╝|Pitch Blk|Prem pkg|Moonroof|SVT Snorkel|SVT Susp|Steeda STS|Z-Eng RMM|Magnaflow exh
TboneZX3 is offline
