Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Cranking But No Start Issues
Old 09-26-2012, 05:54 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,294, Level 100
Points: 32,294, Level: 100 Points: 32,294, Level: 100 Points: 32,294, Level: 100
Forum Activity 4%
Originally Posted by DNoda View Post
I used some duct tape I had and taped down the clutch switch so I could start it easier, and off I went.
That's usually a cause of no-crank, no start issues, so I don't think you need the tape on the CPS.
When is the last time you changed the fuel filter?
How long does the fuel pump run when you turn the key from Off to On? If it runs for more than 3 seconds, then you have a fuel pump that is on it's way out.
Vacuum loss can prevent starting when the engine is cold because the fuel mix will be too lean.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
