Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SYNC Update Available on Focus!!!
Old 09-25-2012, 07:27 PM   #262
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
Originally Posted by Kabigon View Post
I already investigated that possibility but that doesn't seem to be the case.
People that have upgraded from 3.0.2 (12023) have had mixed results.
Other possibilities include a communication problem between the APIM and HVAC module which may indicate different firmware in the HVAC module or the IPC (Instrument Panel Cluster), which acts as a gateway between the HVAC module (MS-CAN bus) and the APIM (I-CAN bus).
I was looking for a way to force the update again but ran out of time.
Out of curiosity, why on earth would the IPC act as a gateway between the APIM and HVAC module? I am assuming you have schematics or some kind of inside knowledge on this based on your comment.
oritpro is offline
