Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 5-Door tail lamp scratching body
Old 09-25-2012, 02:00 PM   #166
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 ST
Points 4,254, Level 41
Points: 4,254, Level: 41 Points: 4,254, Level: 41 Points: 4,254, Level: 41
Level Up 52% Completed
FF Reputation: 3 cbdallas Good Standing Member
If you want to save your self some time and trouble, just pop the hood and adjust the two rubber hood stops mounted just behind the grille. Unscrewing them a small amount will raise the spot where the hood rests and will keep it off the headlights. Don't overdo it....you're only looking to add a couple mm of clearance, and you don't want to get your fender/hood gap out of whack. This is likely the same procedure your dealership will follow. If the Q/C guy was taking a nap when your car rolled off the line, these adjusters probably got missed.
cbdallas is offline
