Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Scheduled 30K DCT maintenance?
Old 09-25-2012, 11:21 AM   #44
bball40dtw
Fan#: 85847
What I Drive: 2013 Ford C-Max SE
Points 778, Level 14
Points: 778, Level: 14 Points: 778, Level: 14 Points: 778, Level: 14
Level Up 78% Completed
FF Reputation: 1 bball40dtw Good Standing Member
Originally Posted by Pretherius View Post
No. And a BIG "NO" when that's the manufacturer's recommended interval.
^ This.
You're not hurting anything by doing it more often, but I'm not sure it's merited. To me, if they're recommending doing it at 150K and you're doing it every 30K, that's a lot like taking a 10K recommended oil change interval an doing an oil change every 2,000 miles. If the peace of mind is worth the money, go for it.
Just IMHO, $200 for that service isn't crazy. But it IS all the more reason to learn how to do it yourself. Truthfully, if it's as simple as a drain plug and pumping a couple quarts of fluid, yeah I'd probably do it myself every 50K or so; it should be too cheap and easy not to. But for $200 a pop, it's really questionable.
The VW procedure isn't as simple as drain and fill. The fluid has to be at the right temp and you need VAG-COM to do some of it. $200 is way too much because parts should be less than $50. It shouldn't take a Ford mechanic much more time than an oil change.
bball40dtw is offline
