Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - leds in headlights
Old 09-24-2012, 10:42 PM   #2
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 8,313, Level 61
Points: 8,313, Level: 61 Points: 8,313, Level: 61 Points: 8,313, Level: 61
Level Up 55% Completed
Level up: 55% Level up: 55% Level up: 55%
Forum Activity 10%
Activity: 10% Activity: 10% Activity: 10%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
There are a number of places you can get leds such as Vleds, Superbright Leds, JdmToy etc.... Just google and you'll find them. Guessing you still have stock lights. If you want them in the housing you you will need to separate the front clear housing from the body. This usually entails baking the headlights one at a time in an oven at around 275 for about 5-7 minutes or so. Its long enough to soften the sealant but not melt or crack the lights. I just used a heat gun and started at the outside top corner and worked my way around. Once apart you need to remove the rest of the sealant so when you seal them back up you can get a good seal. The inner chrome bezel comes out. At this point depending on what leds you got and how they mount you can put them in the housing and then run your wire. Then once your done with that part just reassemble and reseal your lights and hook up the power.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is offline
