Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Add an Auto Dimming Mirror
Old 09-24-2012, 05:37 PM   #14
ibedoughboy
Fan#: 93050
What I Drive: '12 Focus SE Hatch 5 speed
Points 288, Level 5
Points: 288, Level: 5 Points: 288, Level: 5 Points: 288, Level: 5
Level Up 76% Completed
FF Reputation: 2 ibedoughboy Good Standing Member
Originally Posted by slow3v View Post
More then enough. You do realize rear view mirrors are on two articulating balls usually. You should be able to adjust the angle of your mirrors arm. Go tug on it.
Sent from my SGH-I777 using FF Mobile
Yes, the arm on the Chrysler mirror is physically shorter than the Focus mirror. I didn't think to measure it before installing. I'll look at my friends junkyard next time I'm there and see if there's something else with a Gentex mirror w/ a longer arm I can directly plug in.
Just a quick question. What is the power source were tapping into, specifically.
I'm not sure. I used a voltmeter and checked the plug until I found one (there's actually two) pins that are only accessory powered. I'll see if I can get a pin-out from the Ford dealer when I'm there Saturday.
'12 Focus SE Hatch; Oxford White, 5 speed, 203A, SE Sport and Winter Pkg, Moonroof, M&P wheels
'05 BMW Z4 Roadster 6 speed
'62 Chevy Corvair Rampside
ibedoughboy is offline
