Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT header questions
Old 09-24-2012, 10:03 AM   #19
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
Points 6,181, Level 51
Points: 6,181, Level: 51 Points: 6,181, Level: 51 Points: 6,181, Level: 51
Level Up 16% Completed
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
Doesn't make much sense to put a new header in and not do the exhaust. You're gonna be restricted at the exhaust and if you're gonna go through the trouble of cutting off exhaust bolts at the flex might as well do everything. The svt flex doesn't bolt up to the regular exhaust flange anyway unless you slot the bolt holes or replace the flange. Used Svt exhaust can be had for under $100 and it's 2 1/4 inch mandrel bent stainless steel. Unless you are putting in a turbo that will be plenty big.
And $500 is at the very low end if you can find everything used, but I suppose it's doable.
HN #171
Black&Tan is offline
