Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Scheduled 30K DCT maintenance?
Old 09-24-2012, 12:07 AM   #38
Kabigon
Fan#: 88299
What I Drive: 2012 sterling gray Titanium
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 5%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by PratoN View Post
True, but it's been happening when they have seal leaking issues... I'm not quite sure how they're related, though. Does the leaking fluid get into/on the clutch and ruin it that way? Whatever it is, the TSB calls for new seals and clutches (as well as the adaptive learning cycle) when there is transmission fluid leaking from the seal.
Every so often (at low speeds and low engine RPM) I hear the noise from the clutches that I believe people are referring to as the "grinding noise". Otherwise, I have no problems whatsoever.
I'm not sure if a leaking oil seal makes it worse but I have read posts from some folks that have had their clutches replaced and they say that the grinding noise is gone.
The point of my previous reply is that the "grinding noise" is not something related to the transmission "box" itself so changing the oil more frequently is probably not necessary or helpful.
Kabigon is offline
