Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - replaced fuel pump still cuts out on corners
Old 09-23-2012, 09:41 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,470, Level 100
Points: 32,470, Level: 100 Points: 32,470, Level: 100 Points: 32,470, Level: 100
Forum Activity 49%
Activity: 49% Activity: 49% Activity: 49%
Are you referring to the charcoal canister? That scavenges fumes from the gas tank and converts them back to liquid gasoline, then that gets sucked up into the engine through the purge valve. A clogged charcoal canister will cause a "whoosh" when you open the fuel cap.
Did you replace the external fuel filter when you replaced the pump? A fuel filter should be purchased at the same time as the pump even if it's been recently replaced in order to honor any warranty.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
