Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 ZX5 Sudden loss of power, no codes, timing problem?
Old 09-23-2012, 09:08 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,439, Level 100
Points: 32,439, Level: 100 Points: 32,439, Level: 100 Points: 32,439, Level: 100
Forum Activity 52%
Activity: 52% Activity: 52% Activity: 52%
Originally Posted by BC_ZX3 View Post
ECUs rarely go wrong. Hard brakes is the only symptom you've mentioned that seems out of place.
That could be indicative of multiple problems. The coil is a usual suspect for lack of revving along with the TPS, and the PCV vacuum line is the usual suspect for lack of vacuum. In this case, after inspecting that one I'd also inspect/replace the vacuum check valve which is the hard plastic connector that the vacuum line goes into on the power brake booster. You might be noticing some hissing when you hit the brakes.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
