Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Clean a Zetec IAC
Old 09-23-2012, 08:41 AM   #32
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: 2001 Mustang GT Premium
Points 5,708, Level 48
Points: 5,708, Level: 48 Points: 5,708, Level: 48 Points: 5,708, Level: 48
Level Up 79% Completed
Level up: 79% Level up: 79% Level up: 79%
FF Reputation: 69 TerryB Excellent Standing Member
I don't know what's happening now. I went to move the car last night. I soon as the key was in the "run" position, the engine cooling fans came on. The car would not idle at all when started. I went for a 2 minutes ride around the block. When I put the car in park it idles at 800-900 RPM. After the battery disconnect, it should idle high for at least 20 miles. I just tried the car this morning and it barely idled at all. When I kick the throttle, it stalls on decelaration. The fans kicked on again after the 3rd or 4th stall. I disconnected the battery and I'll let it sit for a while and see what happens. All I touched was the IACV to try and clean it.
No codes shown or codes pending. Hasn't been run long enough to cycle. It's as if the car didn't reset itself at all.
TerryB is offline
