Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Sickspeed Horn Installation
Old 09-22-2012, 05:51 PM   #1
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
Points 4,931, Level 44
Points: 4,931, Level: 44 Points: 4,931, Level: 44 Points: 4,931, Level: 44
Level Up 91% Completed
FF Reputation: 5 DarderSauce Good Standing Member
Cool How to: Sickspeed Horn Installation
Hello everyone,
As promised (even if late) I am doing my write up on my Sick Speed Horn installation. So without further delay, here we go!
Here is what you are going to be using:
Untitled by DarderSauce, on Flickr
- Sick Speed horns (durp)
- A multimeter is helpful but not a must
- Solder Gun (with solder)
- 12 Gauge wire
- Relay Switch
- Fuse for 30 Amp fuse
- 30 amp fuses (ATC)
- Female Spades
Not Pictured
- Heat Shrink
- Ring Terminals
First you are going to want to pop your hood and UNPLUG YOUR NEGATIVE BATTERY TERMINAL. Next remove your grille, here are the four clips that hold the grille on. Once they are off just pull out (wink).
Grille by DarderSauce, on Flickr
Once that is off you can get started. Cut into the wiring harness up near the battery, you are looking for the purple and green wire, this is your power.
Cut this wire up by the battery. Try leaving yourself enough slack so you can mount your relay in a spot that is going to stay out of harmís way. Here is where I ended up mounting mine.
Now you are going to want to put a female spade end on your purple and green power wire and plug it into pin #86 on the relay.
*PRO TIP* SickSpeeds wiring diagram is WRONG, they have the power wire from the stock horn going into pin 87. If you follow their instructions you wonít get da beep!
Wiring Diagram by DarderSauce, on Flickr
So again, stick the power wire from your stock horn in pin #86.
Next you are going to hook your fuse up to the positive end on your battery terminal. Put a ring terminal on one end of the fuse, and a female spade on the other.
You may need to solder in another piece of wire to the fuse wiring in order to get the spade end to reach the relay. This is what I did, donít forget the heat shrink!
Plug the female spade into pin #30 on the relay.
Use your 12 gauge wire and add a ring terminal to one end, and a female spade to the other. This is going to be your ground wire so make it long enough to reach from your ground to your relay. Here is where I mounted my ground wire (not the best pic).
Ground by DarderSauce, on Flickr
Plug your ground wire into pin 85 on your relay.
Now you are going to be running your long length of wire that is going from pin 87 to the horns you are going to mount. This is where you are going to solder in the split to go to horn number 2. Again, HEAT SHRINK!!! Each end should have a female end on it, this is going to be plugged into the horn pins.
When you are plugging the power wire into the horn spades, just put it in either one it doesnít matter. Here is what itís going to look like.
Dicks by DarderSauce, on Flickr
The other wire you see is your ground wire. Each one of has a ring terminal and female spade end. Plug the female spade into the other pin on your horn and put the ring terminal behind your mounting bolt.
After you do this for both sides you are done!!!!
Final product with grille in:
Here is what she sounds like:
Clicky!
Sorry if the write up sucks but let me know if you have any questions
Thanks for looking!
If you can't wear it out, burn it off
DarderSauce is offline
