Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - This may sound crazy...
Old 09-22-2012, 08:50 AM   #15
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 2 bespurcell Good Standing Member
Originally Posted by MattZX3 View Post
Drying is extremely easy....
Sheet the water off the car as mentioned by removing the sprayer.
BLOT dry the car with something like this:
Blot drying is MUCH safer for the paint, as you are not dragging a towel or shammy across the paint. With "the absorber" it will not trap any dirt or debris, so if any dirt gets onto the car while youre drying, you will be smearing it across the paint if you wipe instead of blot.
At that point, the car is 95% dry... Spray some quick detailer over each panel, and wipe dry with a microfiber, and its spotless.
Drying takes a while to do, if you can pull the car into the shade while you're drying, it makes life a lot easier..
That's what I use. It works great.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
