Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Brake pedal goes to the floor sometimes
Old 09-21-2012, 07:10 PM   #15
SoCalFan
Fan#: 71350
What I Drive: 2000 Green SE
Points 246, Level 4
Points: 246, Level: 4 Points: 246, Level: 4 Points: 246, Level: 4
Level Up 92% Completed
FF Reputation: 1 SoCalFan Good Standing Member
On my 2000 with ABS the instructions are to use special Ford test equipment when bleeding the system if air has entered the ABS unit. Since that was not the case, I only had to be sure to bench bleed the brake master cylinder before installation. My fluid was very contaminated so I used this opportunity to dump all of it.
SoCalFan is offline
