Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - FSWerks Header? Buy it??
Old 09-21-2012, 12:17 AM   #27
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
The stock flex pipe is welded to the stock manifold. So unless you wanna cut it off and try to make it work then I suggest just buying their flex pipe. I know it's expensive but it's worth it. I think it will save you some headaches later on when you go to install it.
Just to clarify the 08+ the manifold is NOT welded to the mani cat
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
