Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Interior wiring harness
Old 09-20-2012, 08:40 PM   #6
Fan#: 104011
What I Drive: 03 blus ztw
FF Reputation: 1 Mrwoodmin Good Standing Member
Perfect thanks for all your help. I bought this focus knowing the hatch latch doesnt work nor does the rear wiper. I assumed the typical break in the harness at hatch to vehicle point. Upon removal of the grommet someone has been in there already and fixed some wires, went to the fuse box to check wiper fuse and found a solid connector in there, pulled it out and put in a fuse which blows instantly whether the rear wiper is on or not.then went to rear of fuse box and found some melted wires ( hence the solid connector instead of a fuse) I have a focus junker in which I pulled the rear latch out of and it works in junk car but not new car, so I supect I need to inspect the harness thouroghly, fix the melted wires behind fuse box, change fuses and wiper relays and swap the GEM module before reconnecting the battery. Any advice or does my plan sound good? Thanks Again.
Mrwoodmin is offline
