Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car won't start and DTC dash code says 9318
Old 09-20-2012, 06:51 PM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,430, Level 29
Points: 2,430, Level: 29 Points: 2,430, Level: 29 Points: 2,430, Level: 29
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 7%
Buy-Sell-Trade Rating: (3)
Originally Posted by Jamsen View Post
is it worth trying to charge or should I replace it?
Isn't going to do any harm trying to trickle charge it. However, your infrequent driving pattern is hard on battery life.
Could this low voltage stop things like the fuel pump working but still have enough juice to turn the starter?
No. The starter motor will be the single biggest draw on any battery. However if the battery is a known problem, I'd fix the obvious first and then proceed from there.
Out of intrest what should the voltage of a battery be on a 1.4 focus?
Voltage - approximate charge of a battery (engine off)
12.60 V 100%
12.35 V 75%
12.10 V 50%
11.95 V 25%
11.70 V 0%
When the car is running and the alternator is working properly, you should see 13 - 14.5V as measured at the battery.
BC_ZX3 is offline
