Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - to do list... with timing belt
Old 09-20-2012, 10:01 AM   #1
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 3,143, Level 34
Points: 3,143, Level: 34 Points: 3,143, Level: 34 Points: 3,143, Level: 34
Level Up 62% Completed
Level up: 62% Level up: 62% Level up: 62%
Forum Activity 8%
Activity: 8% Activity: 8% Activity: 8%
FF Reputation: 0 smallblockfever Newbie
So pretty soon i will be ordering a bunch of parts from steve at tousley, and i need some advice before i go ahead with stuff.
I'm pretty mechanically inclined, should timing belt be pretty easy? I've heard that using the bar in a kit helps, but what baout just making marks for the cams and crank pulley to get them to line up again?
struts and shocks- ordering a kit of them, what bushings should i replace with them?
plugs and wires- ima check out the threads on here
brake pads and rotors- best brands? i just want a small step up over stock
slave cylinder- need one, hard to replace? or should i get shop to do it
idler pulley, water pump, ac compressor, alternator- gonna replace that when i do timing belt just to knock out rotating assembyl while im messing with it. Any tips when i go to do this?
what kind of tires do you guys like?
smallblockfever is offline
