Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - having problems removing my egr valve
Old 09-20-2012, 07:29 AM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 14,484, Level 78
Points: 14,484, Level: 78 Points: 14,484, Level: 78 Points: 14,484, Level: 78
Level Up 9% Completed
Forum Activity 99%
FF Reputation: 21 Magus2727 Great Standing Member
who is "he"... a parts place? a auto shop? take it to an autozone or similar and they will let you use a code scanner. fairly easy to operate and you operate it so you can write down the codes and then come back. with out knowing the codes its harder to diagnose your problem. I would say you have two unrelated problems. the EGR may have rust all the get go on the out side but will still work fine (just not all that great to look at). look at the DPFE / pressure sensor first... only 20-30 bucks on rockauto.com and takes 5 min to replace.
Magus2727 is offline
