Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008 focus sel
Thread: 2008 focus sel
Old 09-19-2012, 06:09 PM   #3
Geezer
Fan#: 1427
Originally Posted by Bigg Flaco View Post
what tools do i need to remove the front caliper and pads?
No "special" tools are needed. Metric wrenches and /or sockets are needed. A screw driver to remove brake springs, a pair of pliers and a C-clamp to compress the caliper piston (although I have also used some big channel locks and a small block of wood to do so).You'll need a small open end wrench (7 or 8mm if I remember correctly) and some clear vinyl or rubber hose (that will fit on the brake bleeder fitting) to bleed the system (bleed all four corners not just the fronts).
Geezer is offline
