Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Mk3 Recalls and TSBs
Old 09-19-2012, 02:28 PM   #15
blasman
Fan#: 102236
What I Drive: 2012 SEL
FF Reputation: 1 blasman Good Standing Member
TSB List as on 9/19/12 For 2012 Focus
Tsb 12-08-20 - reduced driving range, intermittent no start or no high voltage battery charging
tsb 12-08-11 - 2.0l gdi - front control interface module (fcim) illumination flickering or prematurely dimming in low ambient light conditions,built on or before 5/15/2012
tsb 12-06-17 - crunching or creaking noise from front of vehicle on low speed turns and bumps - built on or before 4/2/2012
tsb 12-05-05 - 2012 focus 2.0l gdi with manual transmission - calibration update - various drivability improvements - built on or before 2/29/2012
tsb 12-05-04 - 2012 focus - 2.0l gdi - dtc p0010, p0012, p0013, p0014, p052a or p054b - vct oil control solenoid - built on or before 5/6/2011
tsb 12-05-02 - 2012 focus 2.0l gdi - oil leak - rear upper exhaust manifold stud area
tsb 12-04-13 - 2012 focus low washer solvent warning message may not display on vehicles built on or before 1/14/2012
tsb 12-02-17 - 2012 focus steering wander - built on or before 12/12/2011
tsb 12-02-15 - 2012 focus passive anti theft system (pats) spare key programming issues - without intelligent access - built on or before 2/22/2012
tsb 12-01-07 - message center displaying horizontal lines - erratic fuel gauge - built on or before 8/16/2011
tsb 11-12-13 - 2012 focus - automatic transmission fluid leak
tsb 11-10-01 - 2012 focus - intermittent remote keyless entry (rke) operation - built on or before 8/3/2011
tsb 11-09-14 - 2011 fiesta / 2012 focus - recreational towing - automatic transmission - built on or before 7/15/2011
tsb 11-09-03 - 2012 focus - inaccurate fuel gauge - dtcs p0456, p008a, p1450, p2196 - built on or before 8/3/2011
tsb 11-08-11 - 2012 focus front door to rear door contact at the top weatherstrip
tsb 11-08-01 - visible depression in hood surface
tsb 11-07-13 - 2012 focus battery light on - dtcs may also be present u012d, u0140, b11db, u0422, p2610, p06b8, u0257
tsb 11-05-01 - 2012 focus lack of power steering assist on vehicle start up and dtc c102d - built on or before 4/19/2011
blasman is offline
