Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008 focus sel
Thread: 2008 focus sel
Old 09-19-2012, 01:26 PM   #2
bugman
bugman's Avatar
Fan#: 98366
What I Drive: 2010 Sangria Red SES
Points 132, Level 2
Points: 132, Level: 2 Points: 132, Level: 2 Points: 132, Level: 2
Level Up 64% Completed
FF Reputation: 1 bugman Good Standing Member
Originally Posted by Bigg Flaco View Post
what tools do i need to remove the front caliper and pads?
There are two caliper bolts that are the caliper slides, they are 14mm. Use a socket and ratchet to un-screw them. The caliper then comes off and the pads slide off. Keep in mind you don't want to have the caliper hanging by the rubber brake line, so if you have some rope or even string to hang from the spring thats what I have used in the past.
Don't qoute me but I think the torque specs on the caliper bolts are 35 ft. lbs. If they are over tightened they can break off during driving because of the heat of the caliper when braking. If you are worried about them coming loose buy some blue thread locker for them. It will keep them from coming loose but allow you to take them out when needed.
Here is a Tousley ford diagram of the front brakes. #7 is the caliper bolts, which are actually on the back of the caliper.
2010 Sangria Red SES #051 Sedan
Autolite AR 103 Sparkplugs, Ram-Air AIRAID CAI, LED Tails
bugman is offline
