Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2.25" exhaust
Thread: 2.25" exhaust
Old 09-18-2012, 12:08 PM   #46
Bwill9886
Fan#: 93444
What I Drive: 2013 Rallye Red Civic Si
Points 1,721, Level 24
Points: 1,721, Level: 24 Points: 1,721, Level: 24 Points: 1,721, Level: 24
Level Up 21% Completed
Level up: 21% Level up: 21% Level up: 21%
FF Reputation: 2 Bwill9886 Good Standing Member
Buy-Sell-Trade Rating: (6)
Originally Posted by Sean05 View Post
Me too let me talk to them again and see if I can get any dynos or flow tests; but it makes sense because its smaller it doesn't have anywhere to go and keeps it more compact and hotter thus getting pushed out faster.
Edit: keep in mind borla and magnaflow test with stock headers so it may change if you add a header but one I add my Cosworth if
I chose to do so I'll dyno an see f I can crank out any more with a 2.25 exhaust.
I'm just veering away from custom and went with someone I knew fit. My 05 TruBendz was horible fitment problems till I fixed it. And it was a nightmare fixing them to the point after it was fixed I didn't want it anymore.
That would be great. That's a good point on the header as well.
That's sad to hear about TruBendz kit for the 05. Most guys I've heard using them haven't had such a bad experience. Hell, I'm hoping they or someone comes out with a stainless piping kit so I can change out the crappy stuff I have on now!
Originally Posted by dyn085 View Post
I would like to see dyno's showing a loss with a larger system. Typically, going larger will produce diminishing returns, but I can't imagine an actual loss, especially over stock.
That's what got me as well.
Originally Posted by TitaniumStick View Post
They were probably comparing it on a completely stock motor. I would venture to say that without airbox mods, the 2.5 killed too much backpressure and increased the pumping losses. You have seen that modding airflow makes the smaller exhaust a limiting factor, so going too large on the exhaust could make the smaller airflow a limiting factor. I have no doubt that the 2.5 produced more hp/tq vs. OEM, but it might not have outperformed the 2.25 vs. OEM
Good point.
Bwill9886 is offline
