Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Changing serpentine belt
Old 09-16-2012, 05:27 PM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,843, Level 100
Points: 32,843, Level: 100 Points: 32,843, Level: 100 Points: 32,843, Level: 100
Forum Activity 43%
Activity: 43% Activity: 43% Activity: 43%
I'll fix that ---> serpentine.
I recommend Gates parts for both the tensioner and the belt. You'll want to draw out the pulleys and the belt so that you can put it back on correctly if there is not a schematic for the belt located under the hood.
To release tension from the tensioner, use a wrench or a socket if you can fit one on the bolt in the center of the tensioner pulley, and rotate the tensioner. I usually flip the belt off the crank pulley while holding tension off the tensioner.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
