Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2003 SPI Misfire
Old 09-16-2012, 02:30 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 29,449, Level 99
Points: 29,449, Level: 99 Points: 29,449, Level: 99 Points: 29,449, Level: 99
Level Up 67% Completed
Level up: 67% Level up: 67% Level up: 67%
Forum Activity 100%
haven't looked up those codes yet, just thought I'd mention first that the plugs & wires certainly won't hurt 7 you should take a CLOSE look at the coil and it's wiring while you're at it.
On single coil Focus's, removing the coil & checking the base for cracking solves many issues with similar symptoms if cracks are found, the wiring issue is less common for a particular speed range.
luck!
sailor is online now
