Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Problem with focus starting
Old 09-16-2012, 09:11 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,461, Level 100
Points: 32,461, Level: 100 Points: 32,461, Level: 100 Points: 32,461, Level: 100
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
The codes will go away with time, otherwise you can remove the negative battery terminal for about 10 minutes, then re-install. I suggest idling the engine for about 6-7 minutes afterwards. When you do a hard reset like that, the first thing it tries to do is reset the A/F ratio. This requires 5 minutes of idling after the engine drops out of cold start mode. If you have a tach, you'll notice the idle is slightly high, but after 5 mins it will drop to normal. If you touch the accelerator during this time, it will restart the test.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
