Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to: Tail light tint
Old 09-15-2012, 10:42 AM   #7
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
Originally Posted by dyn085 View Post
Good write-up and the tails look great
I would also recommend, for those concerned with reversibility, that the sanding step can be skipped pre-spray. Then, should the need arise, the spray can be removed with gasoline (or the like) with no scratching visible on the lenses.
A cheaper (and safer!) equivlent would be paint thinner or acetone. It removes the tint real good, you barley have to rub!
Also if you are concerned about reversibility as well as durability. VHT does a RED nite shades, which can be used to reverse everything back to stock. Even if you sand.
** Also added how to remove the hatch light and 2 rear reflectors **
Chickenmuffn is offline
